Hi, i was just wondering if it’s possible to send a program change via midi to change pedalboards ?
It’s possible. See Changing snapshots with midi - #2 by KAOSS for an example.
You have to edit /var/modep/profile5.json and set midiChannelForPedalboardsNavigation to the desired MIDI channel minus 1. So value 0 for Ch. 1, value 5 for Ch. 6, etc…
The Web UI must not be connected for the pedalboard to change using a Program Change message. That’s the way MOD team programmed it.
