MODEP - MIDI Mapping Label
@Giedrius hoping you might be able to help here. I’m working on an extension to my MIDI pedalboard where I want to use MOD’s MIDI “Label” on my pedalboard:
When I change this value, click Save then go back into the setting window whatever I entered in the Label field is reverted to the previous value. I can’t find where this information is being saved. I see from MOD’s documentation that field is used for displaying an alternate name on the MOD device’s screen. Is it possible the function to save that is disabled because I’m not using a MOD device?
Wacky Avatar, Jonas!
@resonotter it’s actually the cow from Kung Pow: Enter the Fist with flames coming out of his udders. :slight_smile:
Looks like it’s forced to null when using a MIDI mapping. Might be an unintentional oversight of MOD developers, maybe you could try and modify the scripts to save it properly:
@Giedrius thanks for pointing me in the right direction. I’m going to take a shot at making the change, seems pretty straight forward.
