Hi everyone,
I am building a loopmachine using puredata rpi and arduino (as a controller).
Can I use MODEP before Puredata so I can record a loop with an effect (before pure data) ?
or
Add an effect using MODEP on a recorded loop (after pure data) ?
You can run patchage to customize the audio routings. You’ll have to do it manually each time though, it’s possible to replicate the same connections later on using jack_connect command, you could write a script to set it up as necessary once you know what you want to have.
Good to hear! Do you mean with a script …using .desktop or .service?
I mean a .sh file you could easily execute from anything
