We use tools, such as cookies, to enable
essential functionality on our site and to collect data on how you interact with it. By clicking 'I
Accept', you agree to our use of these tools for marketing, analytics and support.
Our Privacy Policy & Cookie Management
First of all, Midihub is amazing! A central MIDI routing piece of my live setup.
I just find myself wishing it was… even more compact? 4 + 4 MIDI DIN connectors, while standard, require a large surface area on the device, similarly the USB Type-B connector is also bulky. Would love to see a next gen version with:
3.5mm MIDI in/out (4+4 is more than enough)
USB-C for power and PC connectivity
Much smaller device box + tighter cabling for a more compact footprint
Optionally, Bluetooth MIDI support?
Oh and the current rubber legs can basically be used to PAINT on white surfaces
Yes, it would be cool to be able to manage some basic settings with a combinations of button pushes. i.e. presets, inputs, outputs, press quickly, long press, press together, press at startup. I guess the more options the better without having to use the software editor.
Oh, and please consider giving users the ability to edit the ‘device name’ (USB-MIDI and Bluetooth) which is shown in the OS. This is necessary if you want to run multiple devices via USB in the same OS to differentiate them. Pirate MIDI has added just that, my feature request on their Bridge4/6 MIDI foot controllers, it’s very cool. Thanks a lot for that!
Ideally also allow to hook an USB hub on the USB-A host port for the potential Midihub v2.0, so we can connect more USB-MIDI controller, what would be awesome!
Superdope would be if we can edit the name of each connected MIDI port which is shown in the OS to differentiate them, if technically doable.
MidiHub2: integrated flanges with pre-drilled holes (for desktop securing) which also conform to whatever the closest Vesa mounting hole setup is to the evetnual dimensions of the box so the MidHub2 can be mounted securely onto even the most ridiculous mass produced mounting solutions.
bonus: “MidiHub2Anything” (“anything” can be almost anything, or whatever) is the obvious yet totally sensational marketing gimmick (thank me later blokas advertising division) that also solves 99% of my MidihubOne issues (it wouldn’t not move around).
What would be really really nice would be if it could handle MIDI over USB but then also be used like a USB hub.
Because currently I have my USB devices plugging into a pisound & some of those devices have windows/ios only software that I can’t run on my rpi. So if I want to get into the software I have to start messing around with unplugging stuff and thus programming patches that involve multiple devices is a bit of a chore.
Discovered this when I saw “Midihub [serial#] A”, “Midihub [serial#] B” etc on another used MH I just bought (instead of “Port 1”,“Port 2”, etc).
Turns out that as well as being able to edit the name in Device → Settings…, one can change the port names in Device → Edit Default Port Names…
I thought this was just for internal visibility, but No.
After checking with Giedrius,
I did the above,
disconnected from the Editor
unplugged Midihub,
deleted the ref to the old name in Mac Audio MIDI Setup (I dunno whether PC has some equivalent to get the device to forget the old name),
