I’m working with the Note Range Filter module, and I was very confused why my notes weren’t being filtered. Then I realised in Midihub’s implementation of notes maps the lowest MID note 0 to C-1, but the synth I was using (Deluge) maps MIDI note 0 to C-2.
There seems to be no consensus as to what MIDI note 0 should be so is it possible to add this as either a) an option in the GUI or b) keep note ranges entered as numbers to display as numbers so it’s easy to tell if I got the range correct?
