Hi, apologies if this is not the appropriate place for this question. I have never used midihub or pisound, my knowledge of their features is only from this forum.
My basic question is whether there is any 1st or 3rd party support for any midi mapping features on the pisound.
More specifically, I would like to be able to create a custom midi mapping that would probably be easy with the midi transformations on Midihub. I would like to map a 16-pad controller to elektron digitakt, using pads trigger different start points on same sample track, to create an experience more similar to chopping on mpc or other pad-based sampler.
Although i am pretty confident I could achieve this with midihub, I am curious about using the pisound instead for a few reasons.
Primarily, I would like to use with USB midi controller and afaik midihub doesn’t have USB in for midi.Beyond that, I am interested in some other features of pisound as well and already have several raspberry pi so i’m more excited about it than midihub which I don’t have so many uses for.
I am comfortable with programming so I am not scared if I don’t have nice interface like midihub editor, I just want to be able to achieve a similar result. I know at some level this is possible, I could always write a solution from scratch. I guess my main question is really whether there is some software library or tool that is known to make this type of thing easy on pisound.
, so did not have time to fiddle around, but will definitely give it a try.
