How can I assign a MIDI mapping that would normally come from a USB host device such as the Electra One?
As far as I understand the only way today to make mappings is to arm the target and then play that MIDI message.
This would not work when the messages are coming from an external USB host device because I cannot have the Midihub plugged in to that while still having access to the Editor.
Sorry, @szszoke , I meant using the Tool just to send out CC through USB-A back to uA just for patch set up purposes, Not using a DIN cable.
Being USB-IN it doesn’t matter if a bunch of other devices are using the USB port/ input pipe
(thats also why I started with the “assuming” - by far the easiest way is to just have Elektron connected up
Elektron → {patchbay} → Mac → {patchbay set to approp port} → MH)
Would it be possible to implement manual MIDI assignments?
As a fellow user, all I can say is Blokas is aware of it cos it’s been raised numerous times.
I don’t think I’ve seen and explanation of why they’ve not chosen to implement it thus far.
maybe...
because a Set button next to every Map button bringing this:
