I have had the wonderful hub for a few days. Have it set as a basic pass-thru: A in-> A Out etc.
What I would like to do on A Out for example is have note in a certain range coming in from a certain channel on A In be mapped to another channel on A Out than they are coming in on.
Example:
A In receives note C0 to C2 on channel 1 and sends them on A Out Channel 2 but if it receives note in C#2 to C4 on channel 1 it sends to A Out Channel 3.
Use case is that I have an Aurturia KeyStep Pro which can send on 4 channels but I have a couple of multi-timbral synths I want to send sequencing data to and effectively get a handful more channels out of the KSP with using this technique, I guess I’d probably want to know how to transpose as well so those notes C0 to C2 I can have going to the multi-timbral synth as say C2 to C4 notes as well. With a few other control options to go along with this I could even then implement maybe some dynamic octave shifting as a more complicated option.
Any help appreciated - just a little lost on how this software itself works for something like this.
What would the visual of this look like?
