Meris LVX and Mercury X prEditor
I am considering the MidiHub and need to know that this scenario will work:
Midi controller (Mortrix) to MidiHub to pedals, including Meris LVX and Mercury X, filtering on channels
plus
PC with the Meris prEditor, this involves SysEx, to Meris LVX and Mercury X
The purpose is to be able to edit presets in these Meris pedals from the Meris prEditor as well as sending pc, cc etc from the midi controller without changing cabling.
Should be possible pr spec as far as I can see, but the prEditor does not work thru my ESI interface, so…
We haven’t tried this ourselves, but we know that the Nord Modular editor as well as general firmware updates, SysEx dumps do work ok going through Midihub.
If you do get Midihub, let us know whether prEditor works fine, and even more so if it does not, we’ll make it work. :slight_smile:
Thank you for the answer - reassuring that you will make it work … me thinks it should be straight foreward
Best Regards
