Hi everyone! I hope this is the right section for my question.
I have recently purchased a pisound card for my Raspberry Pi 4B.
Now I’m deciding whether to use Raspberry Pi OS Lite or Manjaro ARM Minimal for my setup.
I’m having some difficulty in figuring out why the output of aplay -L
is different on these two distributions.
Specifically, in Manjaro I’m missing the option “Direct hardware device without any conversions”.
How can I fix this? I tried installing all sorts of alsa-related packages, but I seem to be missing something.
Output of aplay -L
on Raspberry Pi OS Lite:
$ aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
default
Playback/recording through the PulseAudio sound server
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
hw:CARD=Headphones,DEV=0
bcm2835 Headphones, bcm2835 Headphones
plughw:CARD=Headphones,DEV=0
Hardware device with all software conversions
sysdefault:CARD=Headphones
Default Audio Device
dmix:CARD=Headphones,DEV=0
Direct sample mixing device
usbstream:CARD=Headphones
bcm2835 Headphones
USB Stream Output
hw:CARD=pisound,DEV=0
pisound, PS-3WE6378 snd-soc-dummy-dai-0
plughw:CARD=pisound,DEV=0
sysdefault:CARD=pisound
dmix:CARD=pisound,DEV=0
usbstream:CARD=pisound
pisound
USB Stream Output
hw:CARD=vc4hdmi0,DEV=0
vc4-hdmi-0, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi0,DEV=0
sysdefault:CARD=vc4hdmi0
hdmi:CARD=vc4hdmi0,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi0,DEV=0
usbstream:CARD=vc4hdmi0
vc4-hdmi-0
USB Stream Output
hw:CARD=vc4hdmi1,DEV=0
vc4-hdmi-1, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi1,DEV=0
sysdefault:CARD=vc4hdmi1
hdmi:CARD=vc4hdmi1,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi1,DEV=0
usbstream:CARD=vc4hdmi1
vc4-hdmi-1
USB Stream Output
Output of aplay -L
on Manjaro ARM Minimal:
$ aplay -L
null
HDMI Audio Output
HDMI Audio Output
Many thanks in advance!
