Hey everyone!
Is there (or will be) any chance of inverting/limiting the range of incoming CC messages when mapping a parameter in the Midihub?
Hey, yes, we plan to add mapped parameter editor section which will give more control over the mappings.
Great to know it! Can’t wait for it
Thanks, Giedrius!
Have you come any closer to adding a mapped parameter editor section?
Since then, virtual mappings were introduced, which allow preprocessing the MIDI CCs before using the values for controlling other parameters. There’s still some more plans in this area, stay tuned. ![]()
Hi, and thanks a lot for answer. Yes, I found my way around my problem using virtual mapping. The only problem is that it sometimes takes a lot of pipes and virtual ports to shape the mapping parameters. And since the pipes and vps are limited, I am already running into a shortage
