Log in to google services on Chromium?
I just set up Patchbox OS on a Rp3 B+, and it rocks. I’ll be running Pd mostly.
Anyway, I can not log in to any google services. I would like to transfer files to the Rp by downloading from Google Drive. But I can not log in at all. After entering username and password the service loads (gmail or google drive), and then I get immediately signed out and the log in screen pops up again. No difference if I try to log in to Chromium with my google account.
Is it solvable? Or could I get a recommendation for another browser that might work?
Thanks a lot!
Hi, looks like Google disabled some APIs required for Chromium to work, see this discussion: Chromium login issues - Raspberry Pi Forums
As an alternative, I’d suggest using scp to copy files between your computer and Raspberry Pi directly. You ought to find a GUI client for scp, like WinSCP on Windows, then you’d just enter patch@192.168.1.100 (or whatever the IP of the Raspberry Pi is), and then you could easily transfer files between the devices.
Btw, there’s an updated Chromium version available which seems to work ok, here’s how to get it:
sudo apt update
sudo apt install -y chromium-browser rpi-chromium-mods
It worked! Thanks!
I confirm, just did it (my son) on his brand new RB Pi 4 B. And worked flawless…
