Local plugin import
Hi there!! I wonder how to import plugins to modep locally, without patchstorage. Is there a way to do so localy?
Just put the plugins in /var/modep/lv2 folder and restart the services or reboot the system.
sudo systemctl restart modep-mod-ui modep-mod-host jack
I had used SSH to transfer the plugins to my Pi 4B, so I had to run the following commands as well in order for them to show up in MODEP:
sudo chown -R modep:modep /var/modep/lv2
sudo chmod -R 775 /var/modep/lv2
Is there a way to add a basic interface to my plugin as it is not available?
You can look up the following page to learn how to make your own MOD GUI:
https://moddevices.github.io/mod-sdk/modgui/
Although here are a few repos I found that have MOD GUIs built created for some plugins that aren’t available in Patchstorage. You can try looking through them.
https://github.com/popololo46/modgui
https://github.com/zynthian/zynthian-modgui
Which plugin is it BTW?
