Seems like the resolution is affecting the LFO rate, rather than the rate/speed.
eg: 8hz, slow value changes, 128hz fast value changes.
Also as mentioned in another topic - the noise doesn’t seem to be clock synchronised properly.
The resolution is how many times per second the LFO pipes produce messages - this is to make sure that there’s enough processing time to take care of all the MIDI data in the system. You should use higher resolution for fast LFOs and lower res for slow LFOs.
We’ll think about making this parameter to internally adapt according to LFO rate and waveform.
