Latency adjustment
Is there a way to adjust the midi latency like in Ableton Live? Or would that fall in line with the Sync Delay modifier? Since the Midihub can generate clock i think it would be a nice feature to make some adjustments on the fly, without having to bounce back and forth between DAW’s. It could help with external hardware too.
Cheers
Hi, see this relevant topic: Delay midi out by 20ms - possible? Sync delay help
I’ll try it out. Thanks!
