worik
1
Friends
I wish to record all the audio coming out the Pisound output jack
To this end I need the audio equivalent of tee, that can split an audio channel, and send one to fi.e and one to output
I have tried searching the Interweb but I get lost in the dros…
Any ideas?
Try using jack_capture with system:playback_1 and system:playback_2 ports.
worik
3
That was a brain fade.
It took till I had implemented it to realise I only need an input port and write it to a file.
I was taking the “plumbing” analogy too far.
As @Giedrius pointed out jack_capture is more than what I need.
