I just discovered Pi Sound and Blokas and my mind is blown. I am glad I found such thing and my very first question is this:
I would like to convert the audio line in and audio line out to both audio outs.
Is this possible?
For example, I’ll plug a midi keyboard into the Pi Sound module and then I can use both line outs (rather than one dedicated line in and one dedicated line out)
If this is possible, is it an easy solution? Can it be changed via settings or does it need to be hacked-ish to get this working?
I guess I don’t understand what you’re trying to do. Not sure if you’re using MODEP but you can route audio to each output separately then get a stereo splitter for the output jack.
That’s an interesting idea, I’ll think about that.
Here’s a better way to put it:
Pi sound comes with two quarter inch stereo audio jacks.
Let stereo audio in represent A.
Let stereo audio out represent B.
I would like A and B to be both mono outs
Why? Well, in the example I gave, using Mixxx (dj software) in say, Raspbian OS,
I would like to:
send channel 1 mono out (the first music track) to A
and
send channel 2 mono out (the second music track) to B
(note this is possible in Mixxx)
That way, in any club setup, I simply plug channel A cable and channel B cable into ANY mixer separately in their own channels, no software drivers needed.
Why would I do this? If I were to using Mixxx on raspi, bringing this to a club would likely have a Pioneer mixer, meaning I cannot download Pioneer drivers to use as an audio interface for Mixxx because they only work on Mac and Windows.
This solution will be clean as all I would need to worry about is plugging in channels A and B to the mixer, ANY MIXER. That’s it, no software driver issues to worry about.
Now, my question is, can A and B be adjusted within the raspi to be mono outs or is there a physical limitation on these audio jacks which make it not possible?
You can get cables or adapters to split a single stereo jack into two mono ones, for just a few bucks.
Just search for stereo to mono jack and you’ll find some, although most results will show a 3,5mm stereo jack on one side, which again can easily be adapted to 1/4".
