Impulse response plugin
Okay, I cloned the repository, installed the listed dependencies and ran the make/make install without errors. The plugin folder was copied to /usr/local/lib/lv2 but after rebooting the Pi I still can’t see the cabsim plugin in the list of available plugins.
Was the plugin supposed to be copied to another folder? There are no other folders in /usr/local/lib/lv2 except the cabsim folder.
The directory is /var/modep/lv2
Works great! For any bassists here I found a nice pack of various bass cabinets here and they work with MODEP;
https://shift-line.com/irpackbass
Ok so after ive really had the the time to try out cabsim, i notice that impulses sound really different than they should. On my workstation i use mostly melda’s convolution plugin that i know sounds the way it should with a particular IR. If i compare the two, cabsim sounds completely off. It doesnt have anything to do with the time limit of 40 ms that cabsim has. Can anyone confirm Ir’s sounding different with cabsim? And if so is there anything i can try?
