How to install Alsa Driver
Hi there - I am trying to get a Tascam US-428 going on RPi/Patchbox OS. My goal is to use the US-428 as a midi control surface but for now I’m stuck trying to install the drivers. The RPi is connected to the US-428
**patch@patchbox**:**~ $** lsusb
Bus 002 Device 002: ID 1005:b128 Apacer Technology, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 1604:8000 **Tascam US-428 Audio/Midi Controller (without fw)**
Bus 001 Device 004: ID 045e:0083 Microsoft Corp. Basic Optical Mouse
Bus 001 Device 003: ID 1235:8202 Focusrite-Novation
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I found this instruction saying to install the Alsa firmware Tascam US 428 for Mint - LinuxMusicians
and these instructions on installing the driver Matrix:Module-usb-usx2y - AlsaProject
But I can’t follow them. How do I install the driver? Thanks! Specifically I don’t know how to create the symbolic link, described here:
Note also that the kernel module **soundcore** has been renamed in Debian kernels >2.6.23 into **snd** . A workaround is to put a symlink at /lib/modules/x.x.xx/kernel/sound/soundcore.ko pointing to **snd.ko**
Use the ln command: https://linuxize.com/post/how-to-create-symbolic-links-in-linux-using-the-ln-command/
Hope this helps,
John
