Is it possible to treat the left and right audio channels as two independent (mono) channels?
Giedrius
2
Sure, as long as they are using the same audio settings (format, sampling rate), some users choose to desolder the stereo potentiometer and use two mono potentiometers instead to have individual channel volume control.
Related topics
| Topic | Replies | Views | Activity | |
| Is it possible to convert both audio female jacks to line outs? | 8 | 447 | November 18, 2022 | |
| No Input an the r channel | 5 | 222 | February 20, 2024 | |
| Pi Sound Removing Knobs and Button | 1 | 1039 | June 11, 2019 | |
| Is it hard to desolder the pots and button? | 6 | 1733 | January 25, 2018 | |
| Redirect pisound audio to rpi 4-pole jack | 10 | 334 | April 29, 2023 | |
| Unbalanced output only? | 3 | 462 | January 21, 2021 | |
| Are pisound circuit designs available? | 16 | 4104 | February 18, 2020 | |
| Pisound only outputs one audio channel | 4 | 336 | July 28, 2023 | |
| Aggregated device? | 1 | 569 | October 18, 2018 | |
| Expected behaviour when using a ts mono input? | 4 | 1005 | February 23, 2018 |
