Having a Harmonizer option to NOT play the incoming note would allow for more creative uses.
It could be set to on by default to comply with existing behavior.
So if Play incoming Note is OFF and all intervals set to +0, it would behave as Filter out all Notes?
Use Transpose pipe prior to Harmonizer to change the ‘base note’ it works with, then do appropriate intervals in the harmonizer.
I think what @dannytaurus is conceiving is playing say, the 3rd, 5th & 7th without playing the root. I can imagine this, particularly when mapped on&off, adding “more creative use”
@Giedrius And to get the root note on/off mappable I would just map the bypass of the Transpose?
@resonotter Yep, exactly
Still, I would rather have this as a Harmonizer option, where it seems to belong.
Yes, of course that would shift how it is harmonized as well.
We’ll add this to our todo list. ![]()
