I set up a fresh PatchboxOS, and I’m running a PureData patch that generates audio. Everything seems fine, it’s playing audio out of the headphone jack no problem.
I’ve compiled ffmpeg from source
Listing my sources returns the following:
$ ffmpeg -sources alsa
Auto-detected sources for alsa:
* default [Playback/recording through the PulseAudio sound server]
null [Discard all samples (playback) or generate zero samples (capture)]
jack [JACK Audio Connection Kit]
pulse [PulseAudio Sound Server]
usbstream:CARD=ALSA [USB Stream Output]
My ffmpeg script for good measure:
ffmpeg \
-re \
-f alsa \
-i default \
-stream_loop -1 \
-re \
-i loop.mp4 \
-shortest \
-ar 44100 \
-c:v copy \
-c:a aac \
-f flv "$URL"
This all works fine, except no audio. I’ve tried every permutation that I can think of, but I must not be understanding something.
Questions/Notes:
- Does anything else need to be pre-configured? Patchage?
- Pd: Media > ALSA logs
ALSA input error (snd_pcm_open): No such file or directory - Is
-f alsa -i defaultcorrect?
Any pointers would be huge, thank you!
