Hi. Is there a simple block in MIDI HUB to generate a simple note (with mapping for pitch and length)?
Use case:
When a clock signal is reveived (for instance from a ‘clock’ in midihub) then that block plays a note.
And when an other cc is mapped to the tempo then we have a lot of functionality to play a synth without need for a computer or other device that generates the note.
Hey, it’s not available currently - some external input would be needed to feed some ‘seed’ notes into Midihub, but it’s likely to be implemented down the line.
Hi @Giedrius. Thank you for your reply. The idea is to be able to work without external ‘seed’ notes and to have the note triggered by the internal clocks.
