Dear all,
I have two FreeDrum sticks (drumming in the air, gives bluetooth MIDI), and I had them working on Raspbian by installing bluetooth 5.48 (https://mclarenlabs.com/blog/2019/01/korg-microkey-air-37-bluetooth-midi-keyboard-with-raspberry-pi/ ) and fluidsynth. Now, yes it worked, but way too much latency. So I am trying patchbox OS.
- I am trying the same bluetooth upgrade as mentioned in the URL above, however the bluetooth is -after the update to 5.48- quite unstable. I can not really configure the bluetooth graphically (it resets now and then), and at the commandline with bluetoothctl it gives “Waiting to connect to bluetoothtd…” frequently. Is there something I should do to free bluetooth from any pre-installed things?
And, perhaps an idea to upgrade to bluetooth 5.48 out of the box in a next image? Would be nice to use MIDI through bluetooth by default (it is updated in the new buster raspbian updates).
Secondly, aside from bluetooth, when I start fluidsynth
fluidsynth -a jack -m alsa_seq -R no -C no -j /usr/share/sounds/sf2/FluidR3_GM.sf2 &
it gives a lot of error messages
Cannoc connect to server request channel
exec of JACK server (command="#!/bin/sh") failed: No such file or directory
JackShmReadWritePtr::ackShmReadWritePtr - Init not done for -1, skipping unlock
fluidsynth: error: Failed to connect to Jack server.
I am not used to jack, so, what am I doing wrong? I assume that starting up fluidsynth is quite basic. I do not have any hardware added, this is just a plain naked PI3B+. -
Thirdly. How am I ever going to get this working automaticly? Are these alsa_seq ports always on the same place? I hate this ‘aconnect’ stuff because I do not want to work with assigning virtual devices, but I want to connect these hardware drumsticks permanently to fluidsynth. Is there an other way than aconnect? I want this to run headless and when I plug in the power (combined with a bass amplifier in one box with a 3A amplifier and a 16A batterypack ).
Super super thanks for hints!
Niels
