First Run failure with/without monitor connected: from iMac 7,1 El Capitan. I got this:
bash$ ssh patch@192.168.1.20
dyld: Library not loaded: /usr/local/opt/openssl/lib/libcrypto.1.0.0.dylib
Referenced from: /usr/local/bin/ssh
Reason: image not found
Trace/BPT trap: 5
Will try re-flashing. UPDATE: Working after re-flash; but ssh’d from High Sierra MacBook Pro. Maybe the Captain has had his last biscuit… Even brew is abandoning it.
UPDATE#2 – I’m using a HiFiBerry DAC+ but it isn’t listed and the compulsory setting of Jack didn’t work – no instructions as to what to do at this point so the setup process failed. Now doing a very long package installation. It might be finished by the end of next week…
