Hello,
Just digging in to my new Midihub, is there a way to filter out a note completely if it has 0 velocity? I would like to put a filter after the “Delay” object such that I only get the delays, not the original note.
Hello,
Hi, 0 velocity Note On events are considered as Note Off events.
For the intended effect, use Dry/Wet parameter of Delay pipe - set it to 100% so that original notes are not played, and only delayed notes are produced.
