This is a companion discussion topic for the original entry at https://blokas.io/pisound/docs/FAQs/
Can I configure the DHCP of pisound to always assign the same address to the tablet/phone that connects? This is in order to send messages back from my app to the tablet without entering the tablet’s ip address each time
Yes, add a line like this to /etc/dnsmasq.d/wifi-hotspot.conf and restart the hotspot:
dhcp-host=01:23:45:67:89:ab,172.24.1.50
01:23:45:67:89:ab should be replaced with the MAC address of your tablet/phone.
Use cat /var/lib/misc/dnsmasq.leases to see the connected clients with their MAC addresses. The IP must be in the range [172.24.1.50; 172.24.1.150], as defined by dhcp-range in dnsmasq.conf.
See https://www.linux.com/learn/intro-to-linux/2018/2/dns-and-dhcp-dnsmasq (Set Static Addresses from DHCP section) for more info.
Hi Giedrius,
I have set up the wifi hotspot, but, when I try to connect to it on my phone, I just get a spinning wheel. Can you help me to trouble shoot this?
thanks!
Hi. I’m having trouble controlling orac with midi via touchosc. The client from my iPad is sending midi to the piSound (I see the light flashing) and I can control orac with a usb midi controller, but sending midi from touchosc doesn’t get received by orac. Is there any way to make this work?
Thank you!
By the way, I made a live change that got it working (running “aconnect 132:0 133:0” see below). Is there a way to change the /usr/local/patchbox-modules/orac/amidiauto.conf to establish this without having to do it manually? I don’t fully understand how that file works. Thank you for help you can provide!
**patch@patchbox** : **~ $** aconnect -l
client 0: 'System' [type=kernel]
0 'Timer '
1 'Announce '
Connecting To: 129:0, 128:0
client 14: 'Midi Through' [type=kernel]
0 'Midi Through Port-0'
Connecting To: 129:0[real:0]
Connected From: 129:0
client 20: 'pisound' [type=kernel,card=1]
0 'pisound MIDI PS-0WAVR0A'
Connecting To: 129:0[real:0], 133:0
Connected From: 129:0, 132:0, 133:1
client 24: 'Launchkey Mini MK3' [type=kernel,card=2]
0 'Launchkey Mini MK3 MIDI 1'
1 'Launchkey Mini MK3 MIDI 2'
client 130: 'pisound-ctl' [type=user,pid=579]
0 'pisound-ctl '
client 131: 'RtMidiIn Client' [type=user,pid=635]
0 'TouchOSC Bridge '
client 132: 'RtMidiOut Client' [type=user,pid=635]
0 'RtMidiIn Client:TouchOSC Bridge 131:0'
Connecting To: 20:0, 24:0, 130:0, 131:0, 129:0[real:0]
client 133: 'Pure Data' [type=user,pid=1107]
0 'Pure Data Midi-In 1'
Connected From: 20:0, 24:0, 130:0, 129:0
1 'Pure Data Midi-Out 1'
**patch@patchbox** : **~ $** sudo aconnect 132:0 133:0
Try including:
RtMidiIn Client:TouchOSC Bridge <-> Pure Data
or
RtMidiOut Client <-> Pure Data
line inside the allow list of /etc/amidiauto.conf. You must restart the service for changes to take place:
sudo systemctl restart amidiauto
The preferred line would be the first one, as it’s a more specific name. Let us know whether the first or second variation work.
@Giedrius: Thank you so much for the help. In the end, I found it worked to make the changes to /usr/local/patchbox-modules/orac/amidiauto.conf instead of /etc/amidiauto.conf.
And I believe both lines were necessary to have the ability to do midi mapping to both the TouchOSC device as well as to my midi controller that was connected via USB.
I may have gotten confused in the permutations, but I can confirm that both settings together do at least work, even if they are redundant.
Thanks again for your help!
Can I use the 3.5 mm jack output of the Raspberry Pi as seconday output in a RNBO (cycling 74) project?
Luigi
It’s better to ask in RNBO community whether it can use multiple audio cards for output, or if you could set up and use some Linux audio server and use it from RNBO in a way to achieve your goals.
Probably it is possible, in practice it can get a little messy and could add unwanted latency.
