I wonder if I am doing anything wrong as I can only get this far when attempting to start Patchbox.
Did it work previously or are you doing this for the first time?
Try verifying the SHA-256 checksum of the file you downloaded, to see if it matches what’s on the website: https://dl.blokas.io/
If it doesn’t match, download the file again, if it does match, try reflashing the SD card, or try another SD card.
Many thanks for your very rapid response. It turns out that it was a successful installation, I have discovered that the screen I am using doesn’t show all of the start dialogue, so I could not see the Login/Password prompt, I thought that the code was hanging. I anticipate that this issue will not happen with a different screen. Again, many thanks for your response, I look forward to having a play with Patchbox. Cheers!
