Hi all!
I’m looking for a EQ like this one: http://www.kvraudio.com/product/eq31_by_piotr_habib_pyrzanowski/details
None of the EQs available right now don’t have the option for 31 or more bands/frequencies at once.
For my specific use I need such a plugin to be all-in-one because of the presets which I need to create so that students can choose them easily and move from one to another…
Also, EQ needs to have an ability to lower the gain down to at least -30dB.
Frequencies should not be fixed, as it is in ZamGEQ31 plugin.
Right now I’m using 4 of “Equalizer TAP” plugins and with my own TouchOSC template I’ve made a 31 band EQ, but that’s not the final solution as there’s no to create a preset for all the frequencies at once…
Changing a whole pedalboard is also slow and can’t be done via MIDI.
Does anyone knows if there’s a way to send MIDI values to set the dB of for example “Equalizer TAP” Hz band but not as a slider, only a button that sets all parameters at once? If this is possible, this would solve the whole problem above (maybe)…
EDIT1: Possible to install and run these plugins (specifically EQ)? https://github.com/calf-studio-gear/calf
Thank you!
