Hello,
I’m running PD with pisound headless controlled via VNC.
I have a patch basically just made out of a cpitchshift object that used to sound fine, when now it sounds like a ring modulator rather than a pitch shift.
It happens in conjunction with the fact that now after patchbox start up if I press the pisound button once PD wont open, and if it does, it doesn’t enable the dsp or load main.pd from the usb drive.
PD set at 48k using JACK and tried all buffer sizes. Very strange as it used to sound fine! The same patch does sound ok on the mac, perhaps the zexy installer for linux doesn’t have the right version of the Z object?
is there a puredata config file that has more options that the ones in the drop menu? I thought I’d look if anything looks sus.
Edit: as per patchbox settings, PD’s minimoog patch should open at start up, but that doesn’t happen anymore. Tested the speed of the microSD and it’s ok.
Cheers!
