Hey guys, here’s an update for Midihub!
New Bypassed Icons and Bug Fixes!
Now if a pipe is bypassed, instead of getting blurred, it will have a Bypassed box on top.
Also, some important fixes were done to the internal processing engine that improve the reliability of Midihub.
1.9.0 Editor downloads
1.09 Firmware
* All stored presets and microtunings will be removed during the firmware upgrade process * - you’ll have to back it up manually by loading each preset and saving them to disk with different names, a ‘data dump’ function to automate this, and to automatically do that during firmware update is planned to be done before the public release.
1.9.0 Detailed Changelog
- Added new Bypassed icons.
- Fixed event reverse ordering issue when using Virtual pipes.
- Fixed a hang of Midihub which could occur based on the order how Virtual pipes were created.
