Hey guys, here’s one more update for Midihub!
Note Length Pipe!
Note Length pipe changes the length of the notes played through it to the fixed configured length value. Also it can invert the pattern by triggering fixed length notes on Note Off events.
1.8.0 Editor downloads
1.08.1 Firmware (UPDATED)
1.08.1 fixes a Midihub crash which occurred based on the order of how the pipelines were created.
The version in the editor will still appear as ‘1.08’.
* All stored presets and microtunings will be removed during the firmware upgrade process * - you’ll have to back it up manually by loading each preset and saving them to disk with different names, a ‘data dump’ function to automate this, and to automatically do that during firmware update is planned to be done before the public release.
1.8.0 Detailed Changelog
- Added new Note Length pipe.
