Hey guys, here’s another update for Midihub!
3 New Pipes!
Each pipe has detailed documentation in the Context Help section of the editor, let us know if it’s comprehensible enough.
Try using Delay pipe with 100% feedback, Infinite on, Sync on and Delay Time set to 1 Bar, it will then behave like a Looper effect.
1.7.0 Editor downloads
1.07 Firmware
* All stored presets and microtunings will be removed during the firmware upgrade process * - you’ll have to back it up manually by loading each preset and saving them to disk with different names, a ‘data dump’ function to automate this, and to automatically do that during firmware update is planned to be done before the public release.
1.7.0 Detailed Changelog
- Added new Arpeggiator pipe.
- Added new Delay pipe.
- Added new Note Repeater pipe.
