the CC-filter works perfect now for my needs!
I found a bug in the random-node: when I try to enter a value in the negative field it automatically jumps to -127 and I cannot change this value anymore
Thank you, will fix the issue
Hey, just uploaded 1.6.1 editor builds that fix the Negative parameter issue.
works! Thanks for the update
Hey Giedrius,
Thanks a lot for the Update! Works well!!!
Just found a bug which seems to be just an image problem:
I used the TO MIDI A at the end of several pipes. And after loading the patch again, it shows the “pointing to the right arrow” icon instead. But the mouse over text is still correct and the behaviour of the patch is intact.
Hey, can you upload or send me the .mhp file directly? Or is it when reloading the preset on the device?
Jep, it happend when reloading from device.
But after exchanging the TO Midi and saving again, it works now.
I see. Next time you notice such weird state in the pipeline, please try saving the current pipeline to a file and send it to me, it may help to determine the cause.
