Hey guys, here’s a minor update for Midihub!
New Sustain Mode - Chord Sustain
An extension to the Sustain pipe was added - a Mode parameter with two options: ‘All’ and ‘Chord’. ‘All’ sustains all played notes until the pipe’s Sustain is off or it gets bypassed. ‘Chord’ mode adds notes to be sustained while at least one note is being held down, then once all notes on the keyboard are released and a new note is pressed, the previous notes will get turned off, and then the new notes will get sustained. This is useful when you want to change the sustain chord without manually triggering the sustain on and off.
Works nicely on the left of an Arpeggiator pipe.
1.10.0 Editor downloads
1.10 Firmware
* All stored presets and microtunings will be removed during the firmware upgrade process * - you’ll have to back it up manually by loading each preset and saving them to disk with different names, a ‘data dump’ function to automate this, and to automatically do that during firmware update is planned to be done before the public release.
1.10.0 Detailed Changelog
- Input Pipes will filter out any ‘note off’ messages which didn’t have a ‘note on’ message.
- Chord sustain mode added.
