Hey guys, releasing a quick update for Midihub and the Editor to fix some of the issues already reported by you.
1.01 Editor downloads
1.01 Firmware
* All stored presets will be removed during the firmware upgrade process * - you’ll have to back it up manually by loading each preset and saving them to disk with different names, a ‘data dump’ function to automate this, and to automatically do that during firmware update is planned to be done before the public release.
1.01 Changelog
Firmware
- Improved The Button debouncing so it doesn’t accidentally skip a few presets.
Editor
- View->Show Toolbar option added.
- View->Zoom submenu added to allow customizing the pipe icon size.
- Updated docs to more explictly mention the port mappings and the reserved port.
- Backspace can now be used to delete pipes.
- All context menus now have ‘Remove’ option for pipe deletion.
- In the Settings menu, The Button section clarified to be customizing the hold action.
