First of all, thank you for Patchbox Os. We tried several Os’ s on the Raspberry Pi, to get a audio workstation. Patchbox is out of the box well configured, to do serieus audio work.
We installed Patchbox mainly to have only one application running. Reaper DAW. And we allways run Reaper directly into ALSA. We don’t need jackd, running. First of all because Reaper doesn’t run verry well over jack, in the Raspberry Pi, it gives cracks and other disconnection misbehaviours. Especialy we run several PianoTeq 8 full version over lv2 in Reaper, and for that we need all cpu power. We don’t need other application running at the same time as Reaper, such as video, e.t.c. Reaper exclusive use alsa, in oure senario.
Right now Reaper will not work after boot, because jack hold back the connection with Alsa for Reaper. We have to go into the terminal, $ patchbox > jack > stop jack after that Reaper will connect with Alsa. As you would understand this is not a workaround.
So we like to disable jack or when that is not posible for the whole system idea. Then we are looking for a script which during the boot after jack is started, jack stops? Or what else would be a fast and consistend solution.
