Disable hotspot ? roll back to regular dhcp?
Hi
I think I enabled hotspot at some point cos the ip is like 172.24.1.1
how do I roll back so it uses dhcp ?
I tried connecting to my wifi router under raspbian, but it does not change the ip and I cannot access the web interface anymore
I am doing a pisound-config, going to hotspot, but I cannot disable it there, this really sucks
there should be an option to roll back
thanks
Are you running on Patchbox OS ? Try disabling it through patchbox utility, there should be a wifi & hotspot menu.
did you read what I write ?
THERE IS NO DISABLE OPTION
Did you read what I didn’t write? :smiley: The option is called ‘down’, do patchbox → wifi → hotspot → down
I’ll resinstall a raspian image and resintall pisound from scratch
it used to work
also when changing the SPID, the script crashes miserably, there must be an update
and NO, I dont use patchbox itself, obviously
