Cycle through Pedalboard Snapshots using the button
Is there a script for cycling through “snapshots” for an individual pedalboard like the prev_pedalboard.sh and next_pedalboard.sh scripts do for the pedalboard button banks?
Not at the moment, but you may try to do it yourself, you may find the available API endpoints in Python code here: https://github.com/BlokasLabs/mod-ui/blob/modep-1.8/mod/webserver.py#L1995
It’d probably end up being similar to the pedalboard switching code as available here: https://github.com/BlokasLabs/modep-btn-scripts
Awesome Thanks … I’ll do some byte chomping!
“set_midi_program_change_pedalboard_snapshots” et al might be the candidate, if I write some, with success - I’ll post it.
Hi there! Just popping in to check on this - were you able to make any progress? I am very interested, as I am hoping to be able to change snapshots with an external midi controller. However I have relatively little programming experience, so a little hesitant to try writing a script!
