Does anyone know if it’s currently possible to view the soundcard, frames, sample rate, etc. settings for Jack? I want to double check how I’ve configured the sound card but can’t seem to find that option. Going through the wizard doesn’t show what the current setting is.
The settings are stored into the jack command line to be used when starting the server at /etc/jackdrc. You may simply run this command to see the parameters:
cat /etc/jackdrc
See here for the argument meanings: jackd(1) - Linux man page
