Convert CC to pitchbend, and other Q’s (Cobalt to Sirin project)
just a quickie (might get more time later)
when are people working with ranges of CCs? that also initially confused me about the CC remap pipe
Lots of uses but maybe not obvious. Will try ping a couple over later.
All part of Transform Power!
i tested my joystick for pitchbend and it does give 16384 values - but what are the LSB and MSB for pitchbend?
check out my pic in above link: PB takes 128 tiny steps (LSB) for every big (MSB) one.
But as you’re going CC → PB you’re gonna lose your fine steps.
don’t understand what Arg 1 and Arg 1 are or MSB to value … the transform pipe is largely gibberish to me!
Transform can set your new message’s properties to aspects of the Incoming (say CC# of CC value) OR whatever numbers are in the Arg1/2 fields.
Super powerful & flexible (means eg you can have just note G8 Transformed to Prog Chg 5 )
but takes a time for most of us to click just how much all this flexibiliy can do.
(That’s why I’m trying to write a guide on it!)
Stick with it; it will Transform your Midihub usage!
Rescale it to what? you mean from 0-127
If your CC → PB is like in my snap above (CC val → PB MSB) you might not want the full range of the CC val → full range of PB MSB. to get a smaller range you might Rescale CC say [0;127] → [32;95] to get less extreme bending
is it possible to do high res remaps? how?
Short answer, don’t try!
Easiest way is to use a controller with endless encoders that churns out NRPNs.
PS. I thought you were going CC → PB (ie. losing res).
Let me know if you’ve got 16384 vals coming out of Cobalt, cos you can do stuff with that!
