Can you control midihub and it’s components itself over midi?
Let’s say we want to change a scale of the quantizer or adjust parameters of the arpeggio?
Can midi hub be programmed using sysex only? Without the editor?
Cheers Tim
Cheers Tim
Nearly every property in every pipe can be mapped
Ranges in Range type Filters:
Channel Range FilterCC Range FilterNote Range FilterPreset in Scale Remap
Auto Frequency setting in Micro Scale
No sysex programming. All via Editor.
Nice!
Thanks for the update. Looking forward to the midihub.
Cheers
Tim
You’re welcome and I’m sure you’ll have a lot of fun.
In the meantime, you can start to build patches/presets with the Editor without having a Midihub connected. (You just can’t test them obviously, or do any mapping until connected)
Also:
while in the Editor use the PatchStorage panel to preview presets there by double clicking and going for some simple ones to start.
(avoid any tagged with ‘loopback’ until later)
check out the How-Tos - there’s a hands-on “New To Midihub” series which you can dive into a soon as your little grey box arrives!
