Control Elektron Octatrack arranger mode with midi
Hi, does anyone knows how to do the “Stop/SPP/Play” sequence that is required to navigate into the OT arranger mode via a midi controller (Spd-sx pro). My goal is to get out of infinite loop while I’m playing drums. As far as I know the Spd-sx pro can only send 1 midi note at the time.
Hope someone can help me!
JP
I know nothing about OT or its arranger mode but…
…in the absence of a more informed response, here’s this:
JPG_OT_arranger.mhp
details:
the patch is based on the assumption that you want to:
  • take one of a range of hit notes on the Roland SPD-SX
  • use each note_on to create a “Stop/SPP/Play” sequence ,
  • where each note number matches to a specific SPP
  • and use Midihub to fulfil your task (you didn’t mention MH in your post)!
(see also the Description Panel of the patch)
I’ve included a short delay because I recall this being a thing with some Elektron devices.
It may be that this should be between the SPP Transforms and the final Start Transform instead…
… or both…
… or is actually unnecessary.
This will become apparent in testing.
@JPG UPDATE: I realised I made an error with the first Transform
Line 1 of this testing version JPG_OT_arranger_check.mhp corrects this.
The other changes...
…are just there for testing and monitoring purposes:
(plus I added a couple more SPP Transforms for variety)
@resonotter Thanks a lot for your help, it’s still not working and I might try find another solution. The OT is responding in a weird way to the command.
@JPG, were my assumptions correct?
If so, all the main line does is:
  • Stop…
  • …pause an instant…
  • …set an SPP (here only for notes 61,62,63)…
  • …(immediately) Start
Now if this is the behaviour you want but…
…it may be that either the pauses need adjusting or just that the chosen positions are jumping to positions that don’t match your arrangement.
So, I would suggest setting up a development/testing patch that breaks up the stages:
  1. Bypass the Clock pipeline so no dummy input
  2. restrict Work with Note Number in Range Low|High for Transform1(note → Stop) to, say, note60
  3. Bypass the Delay pipe
  4. set the 3 SPP transforms to positions that are meaningful to OT arranger
  5. restrict Work with Note Number in Range Low|High to, say, note64 for final Transform(note → Start)
This will allow you to test Midihub control with human timing between the stages:
  • note60 stops OT
  • notes 61,62,63 set chosen position
  • note64 starts OT
If this gives the behaviour you want, then you can make the delay/position adjustments so that a single key will trigger the correct “Stop–(pause)–SPP–(pause)–Play” sequence!
PS. now I know that at least my Midihub query assumption is correct, Iet’s move this to that category…
