I want to turn on/off few pedals with midi but it’s seems to be impossible to do from modep webui. How can I do it?
Welcome to the Blokas community!
You might want to consider using snapshots to save a pedalboard state where multiple effects are turned on at once. I think those can be cycled through via a midi cc. Not sure which one, I don’t have access to my pedalboard at the moment.
See this topic Default Program Change Channel For Changing Snapshots - #3 by protectorate
tyvm, it works, awesome! is this the only way I can bypass multiple pedals?
Your other option is to use one of the switch plugins and put the ones you want to bypass on one side of the switch.
ok, thanks for info, I guess I’ll be using snapshots for now
