Burned up my Pisound?
I fear that I have maybe broken something on my Pisound. I’m building a guitar multieffect with a raspberry pi 5 (with pipewire and wayland). I just finished soldering all the components and made several tests of them connected to the extension headers of the pisound. Unfortunately, when I plugged again my guitar and my amp, I did not hear any sound at all. I first checked the two cables and they work.
Then I checked the devices and everything seems OK (devices appear on qpwgraph and aplay etc. give the correct output).
I also checked the volume and mute/unmute widgets on the RaspberrypiOS desktop and they are OK.
I also removed everything other than the pisound and plugged it in directly on the pi. No change.
I tried it also on a raspberry pi 4 I have and got the same results.
I share a photo of the rp4 with the pisound on it and a view of qpwgraph with the devices.
Do you think I could have broken something that prevent only input and/or output from the jacks? What could I do to verify? I have only a multimeter to test the electronics. Do you think of other things at the software level that could prevent the signal to be sent to the amp?
Best,
Gaël
Try running this command to test audio output first:
speaker-test -c2 -r48000 -Dhw:pisound
It should be producing white noise on the left channel, then on the right one.
Could you also post a picture of the bottom side of Pisound? If there are wires obstructing the view, try to make a couple of pictures so I can visually inspect the surrounding components.
Hi Giedrus,
Thanks for you answer. I got no sound with the speaker-test, but an input/output error. See the snapshot.
I join also photos of the bottom side. I hope they are good enough.
I am absolutly shameful of my soldering skills…
Could you also attach the dmesg log after having run the speaker-test?
Do dmesg > dmesg.log and it will write it to a dmesg.log in your current directory (usually your home directory).
Don’t worry about it, practice helps :slight_smile: Make sure you heat up both, the pad/ring and the pin - the solder flows to the heated parts. Apply solder at around the place where the soldering iron and the other surfaces meet, even better, if it’s possible to not apply it to the soldering iron directly, but on the opposite side of the pin/pad. If solder won’t stick - some flux may be needed, but the solder core usually has it in its internal structure, so most of the time it’s enough to apply the solder wire at the correct location. Additionally, some contacts that connect to a polygon, most usually the Ground plane, require much more heating up time, before the solder flows nicely. The rectangular pin on the header is a Ground pin, so heat it up for a bit more time.
You do have some excess solder on your pins, it would be good to reflow them and remove the excess with a solder wick. The shape of solder to aim for is a cone.
I notice some scratches on the bottom side on the trace along the edge of the board, it may have broken or impacted contact. Please check whether these pins are connected, and measure the resistance:
Thanks for your encouragements on the soldering side. I will try to correct as you suggested.
I put below the dmesg output. For the resistance between the indicated locations, there is continuity and a resistance of approximatively 14.8Mohm.
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[    0.000000] Linux version 6.12.47+rpt-rpi-2712 (serge@raspberrypi.com) (aarch64-linux-gnu-gcc-12 (Debian 12.2.0-14+deb12u1) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.12.47-1+rpt1~bookworm (2025-09-16)
[    0.000000] KASLR enabled
[    0.000000] random: crng init done
[    0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000003a000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000003a000000..0x000000003dffffff (65536 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[    0.000000] OF: reserved mem: 0x000000003fd23160..0x000000003fd23197 (0 KiB) nomap non-reusable nvram@0
[    0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000] Faking node 0 at [mem 0x0000000000000000-0x000000001fffffff] (512MB)
[    0.000000] Faking node 1 at [mem 0x0000000020000000-0x000000003fffffff] (512MB)
[    0.000000] Faking node 2 at [mem 0x0000000040000000-0x000000005fffffff] (512MB)
[    0.000000] Faking node 3 at [mem 0x0000000060000000-0x000000007fffffff] (512MB)
[    0.000000] Faking node 4 at [mem 0x0000000080000000-0x000000009fffffff] (512MB)
[    0.000000] Faking node 5 at [mem 0x00000000a0000000-0x00000000bfffffff] (512MB)
[    0.000000] Faking node 6 at [mem 0x00000000c0000000-0x00000000dfffffff] (512MB)
[    0.000000] Faking node 7 at [mem 0x00000000e0000000-0x00000000ffffffff] (512MB)
[    0.000000] NUMA: Initialized distance table, cnt=8
[    0.000000] NODE_DATA(0) allocated [mem 0x1fffd200-0x1fffffff]
[    0.000000] NODE_DATA(1) allocated [mem 0x3f9fd200-0x3f9fffff]
[    0.000000] NODE_DATA(2) allocated [mem 0x5fffd200-0x5fffffff]
[    0.000000] NODE_DATA(3) allocated [mem 0x7fffd200-0x7fffffff]
[    0.000000] NODE_DATA(4) allocated [mem 0x9fffd200-0x9fffffff]
[    0.000000] NODE_DATA(5) allocated [mem 0xbfffd200-0xbfffffff]
[    0.000000] NODE_DATA(6) allocated [mem 0xdfffd200-0xdfffffff]
[    0.000000] NODE_DATA(7) allocated [mem 0xffd99200-0xffd9bfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000000007ffff]
[    0.000000]   node   0: [mem 0x0000000000080000-0x000000001fffffff]
[    0.000000]   node   1: [mem 0x0000000020000000-0x000000003f9fffff]
[    0.000000]   node   2: [mem 0x0000000040000000-0x000000005fffffff]
[    0.000000]   node   3: [mem 0x0000000060000000-0x000000007fffffff]
[    0.000000]   node   4: [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000]   node   5: [mem 0x00000000a0000000-0x00000000bfffffff]
[    0.000000]   node   6: [mem 0x00000000c0000000-0x00000000dfffffff]
[    0.000000]   node   7: [mem 0x00000000e0000000-0x00000000ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff]
[    0.000000] Initmem setup node 1 [mem 0x0000000020000000-0x000000003f9fffff]
[    0.000000] Initmem setup node 2 [mem 0x0000000040000000-0x000000005fffffff]
[    0.000000] Initmem setup node 3 [mem 0x0000000060000000-0x000000007fffffff]
[    0.000000] Initmem setup node 4 [mem 0x0000000080000000-0x000000009fffffff]
[    0.000000] Initmem setup node 5 [mem 0x00000000a0000000-0x00000000bfffffff]
[    0.000000] Initmem setup node 6 [mem 0x00000000c0000000-0x00000000dfffffff]
[    0.000000] Initmem setup node 7 [mem 0x00000000e0000000-0x00000000ffffffff]
[    0.000000] On node 2, zone DMA: 384 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 15 pages/cpu s193496 r8192 d44072 u245760
[    0.000000] pcpu-alloc: s193496 r8192 d44072 u245760 alloc=15*16384
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Virtualization Host Extensions
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: SSBS not fully self-synchronizing
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:55:1A:27 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=17771377-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=FR usbcore.autosuspend=-1
[    0.000000] cgroup: Disabling memory control group subsystem
[    0.000000] mempolicy: NUMA default policy overridden to 'interleave:0-7'
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Fallback order for Node 0: 0 1 2 3 4 5 6 7
[    0.000000] Fallback order for Node 1: 1 2 3 4 5 6 7 0
[    0.000000] Fallback order for Node 2: 2 3 4 5 6 7 0 1
[    0.000000] Fallback order for Node 3: 3 4 5 6 7 0 1 2
[    0.000000] Fallback order for Node 4: 4 5 6 7 0 1 2 3
[    0.000000] Fallback order for Node 5: 5 6 7 0 1 2 3 4
[    0.000000] Fallback order for Node 6: 6 7 0 1 2 3 4 5
[    0.000000] Fallback order for Node 7: 7 0 1 2 3 4 5 6
[    0.000000] Built 8 zonelists, mobility grouping on.  Total pages: 261760
[    0.000000] Policy zone: DMA
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=8
[    0.000000] ftrace: allocating 45292 entries in 45 pages
[    0.000000] ftrace: allocated 45 pages with 4 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000090] Console: colour dummy device 80x25
[    0.000094] printk: legacy console [tty1] enabled
[    0.000166] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000170] pid_max: default: 32768 minimum: 301
[    0.000263] LSM: initializing lsm=capability
[    0.001045] Dentry cache hash table entries: 524288 (order: 8, 4194304 bytes, vmalloc)
[    0.001426] Inode-cache hash table entries: 262144 (order: 7, 2097152 bytes, vmalloc)
[    0.001461] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes, vmalloc)
[    0.001472] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes, vmalloc)
[    0.002179] rcu: Hierarchical SRCU implementation.
[    0.002184] rcu: 	Max phase no-delay instances is 1000.
[    0.002225] Timer migration: 1 hierarchy levels; 8 children per group; 0 crossnode level
[    0.002572] EFI services will not be available.
[    0.002645] smp: Bringing up secondary CPUs ...
[    0.002833] Detected PIPT I-cache on CPU1
[    0.002871] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[    0.003082] Detected PIPT I-cache on CPU2
[    0.003109] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[    0.003310] Detected PIPT I-cache on CPU3
[    0.003328] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[    0.003356] smp: Brought up 8 nodes, 4 CPUs
[    0.003360] SMP: Total of 4 processors activated.
[    0.003362] CPU: All CPU(s) started at EL2
[    0.003364] CPU features: detected: 32-bit EL0 Support
[    0.003367] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[    0.003369] CPU features: detected: Common not Private translations
[    0.003370] CPU features: detected: CRC32 instructions
[    0.003372] CPU features: detected: RCpc load-acquire (LDAPR)
[    0.003373] CPU features: detected: LSE atomic instructions
[    0.003374] CPU features: detected: Privileged Access Never
[    0.003376] CPU features: detected: RAS Extension Support
[    0.003378] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[    0.003403] alternatives: applying system-wide alternatives
[    0.004938] CPU features: detected: Hardware dirty bit management on CPU0-3
[    0.005119] Memory: 4049792K/4188160K available (14208K kernel code, 2418K rwdata, 4944K rodata, 5696K init, 647K bss, 48800K reserved, 65536K cma-reserved)
[    0.005274] devtmpfs: initialized
[    0.007170] Enabled cp15_barrier support
[    0.007175] Enabled setend support
[    0.007212] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.007218] futex hash table entries: 1024 (order: 2, 65536 bytes, vmalloc)
[    0.007331] 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[    0.007333] 0 pages in range for non-PLT usage
[    0.007334] 129304 pages in range for PLT usage
[    0.007417] pinctrl core: initialized pinctrl subsystem
[    0.007542] DMI not present or invalid.
[    0.010861] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.011185] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.011213] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.011241] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.011253] audit: initializing netlink subsys (disabled)
[    0.011295] audit: type=2000 audit(0.008:1): state=initialized audit_enabled=0 res=1
[    0.011409] thermal_sys: Registered thermal governor 'step_wise'
[    0.011417] cpuidle: using governor menu
[    0.011469] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.011490] ASID allocator initialised with 32768 entries
[    0.011704] Serial: AMBA PL011 UART driver
[    0.012458] /soc@107c000000/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /soc@107c000000/interrupt-controller@7fff9000
[    0.012614] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[    0.012735] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 16, base_baud = 0) is a PL011 rev3
[    0.012744] printk: legacy console [ttyAMA10] enabled
[    0.020957] raspberrypi-firmware soc@107c000000:firmware: Attached to firmware from 2025-10-17T09:48:37, variant start_cd
[    0.024959] raspberrypi-firmware soc@107c000000:firmware: Firmware hash is b66568da00000000000000000000000000000000
[    0.035449] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[    0.035693] iommu: Default domain type: Translated
[    0.035695] iommu: DMA domain TLB invalidation policy: strict mode
[    0.037061] SCSI subsystem initialized
[    0.037091] usbcore: registered new interface driver usbfs
[    0.037097] usbcore: registered new interface driver hub
[    0.037102] usbcore: registered new device driver usb
[    0.037162] pps_core: LinuxPPS API ver. 1 registered
[    0.037164] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.037167] PTP clock support registered
[    0.037416] vgaarb: loaded
[    0.037501] clocksource: Switched to clocksource arch_sys_counter
[    0.037620] VFS: Disk quotas dquot_6.6.0
[    0.037626] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[    0.040248] NET: Registered PF_INET protocol family
[    0.040382] IP idents hash table entries: 65536 (order: 5, 524288 bytes, vmalloc)
[    0.041238] tcp_listen_portaddr_hash hash table entries: 2048 (order: 1, 32768 bytes, vmalloc)
[    0.041256] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, vmalloc)
[    0.041261] TCP established hash table entries: 32768 (order: 4, 262144 bytes, vmalloc)
[    0.041374] TCP bind hash table entries: 32768 (order: 6, 1048576 bytes, vmalloc)
[    0.041712] TCP: Hash tables configured (established 32768 bind 32768)
[    0.041790] MPTCP token hash table entries: 4096 (order: 2, 98304 bytes, vmalloc)
[    0.041816] UDP hash table entries: 2048 (order: 2, 65536 bytes, vmalloc)
[    0.041852] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes, vmalloc)
[    0.041914] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.042037] RPC: Registered named UNIX socket transport module.
[    0.042040] RPC: Registered udp transport module.
[    0.042041] RPC: Registered tcp transport module.
[    0.042042] RPC: Registered tcp-with-tls transport module.
[    0.042043] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.042046] PCI: CLS 0 bytes, default 64
[    0.043120] kvm [1]: nv: 554 coarse grained trap handlers
[    0.043209] kvm [1]: IPA Size Limit: 40 bits
[    0.043218] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[    0.043234] kvm [1]: vgic interrupt IRQ9
[    0.043245] kvm [1]: VHE mode initialized successfully
[    0.239415] Initialise system trusted keyrings
[    0.239561] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[    0.239807] NFS: Registering the id_resolver key type
[    0.239814] Key type id_resolver registered
[    0.239815] Key type id_legacy registered
[    0.239824] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.239826] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.239971] Key type asymmetric registered
[    0.239974] Asymmetric key parser 'x509' registered
[    0.239991] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.240019] io scheduler mq-deadline registered
[    0.240022] io scheduler kyber registered
[    0.240034] io scheduler bfq registered
[    0.240319] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/interrupt-controller@7d510600, parent irq: 27)
[    0.240350] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/interrupt-controller@7c502000, parent irq: 28)
[    0.240377] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d508380, parent irq: 29)
[    0.240406] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d508400, parent irq: 30)
[    0.240437] irq_brcmstb_l2: registered L2 intc (/soc@107c000000/intc@7d503000, parent irq: 31)
[    0.241290] ledtrig-cpu: registered to indicate activity on CPUs
[    0.241477] simple-framebuffer 3fa00000.framebuffer: framebuffer at 0x3fa00000, 0x1c2000 bytes
[    0.241480] simple-framebuffer 3fa00000.framebuffer: format=r5g6b5, mode=1280x720x16, linelength=2560
[    0.241570] Console: switching to colour frame buffer device 160x45
[    0.242004] simple-framebuffer 3fa00000.framebuffer: fb0: simplefb registered!
[    0.271883] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[    0.272162] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[    0.272196] serial serial0: tty port ttyS0 registered
[    0.272424] iproc-rng200 107d208000.rng: hwrng registered
[    0.272454] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[    0.272627] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[    0.273887] brd: module loaded
[    0.274750] loop: module loaded
[    0.274833] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    0.274927] Loading iSCSI transport class v2.0-870.
[    0.275558] usbcore: registered new interface driver lan78xx
[    0.275565] usbcore: registered new interface driver smsc95xx
[    0.275608] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.275622] dwc_otg: FIQ enabled
[    0.275624] dwc_otg: NAK holdoff enabled
[    0.275625] dwc_otg: FIQ split-transaction FSM enabled
[    0.275627] Module dwc_common_port init
[    0.275807] usbcore: registered new interface driver uas
[    0.275814] usbcore: registered new interface driver usb-storage
[    0.275872] mousedev: PS/2 mouse device common for all mice
[    0.283444] rpi-rtc soc@107c000000:rpi_rtc: registered as rtc0
[    0.284834] rpi-rtc soc@107c000000:rpi_rtc: setting system clock to 1970-01-01T00:00:09 UTC (9)
[    0.285111] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[    0.285113] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.287124] sdhci: Secure Digital Host Controller Interface driver
[    0.287126] sdhci: Copyright(c) Pierre Ossman
[    0.287152] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.287211] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.287219] hid: raw HID events driver (C) Jiri Kosina
[    0.287236] usbcore: registered new interface driver usbhid
[    0.287237] usbhid: USB HID core driver
[    0.287491] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 (0,8000003f) counters available
[    0.287697] NET: Registered PF_PACKET protocol family
[    0.287717] Key type dns_resolver registered
[    0.291067] registered taskstats version 1
[    0.291121] Loading compiled-in X.509 certificates
[    0.292505] Demotion targets for Node 0: null
[    0.292507] Demotion targets for Node 1: null
[    0.292508] Demotion targets for Node 2: null
[    0.292509] Demotion targets for Node 3: null
[    0.292510] Demotion targets for Node 4: null
[    0.292511] Demotion targets for Node 5: null
[    0.292512] Demotion targets for Node 6: null
[    0.292513] Demotion targets for Node 7: null
[    0.292688] Key type .fscrypt registered
[    0.292690] Key type fscrypt-provisioning registered
[    0.293366] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@1000120000 ranges:
[    0.293370] brcm-pcie 1000120000.pcie:   No bus range found for /axi/pcie@1000120000, using [bus 00-ff]
[    0.293377] brcm-pcie 1000120000.pcie:      MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[    0.293382] brcm-pcie 1000120000.pcie:      MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[    0.293387] brcm-pcie 1000120000.pcie:   IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[    0.293392] brcm-pcie 1000120000.pcie:   IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[    0.293395] brcm-pcie 1000120000.pcie:   IB MEM 0x1000130000..0x1000130fff -> 0xfffffff000
[    0.294720] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0002:00
[    0.294724] pci_bus 0002:00: root bus resource [bus 00-ff]
[    0.294727] pci_bus 0002:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[    0.294729] pci_bus 0002:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[    0.294740] pci 0002:00:00.0: [14e4:2712] type 01 class 0x060400 PCIe Root Port
[    0.294746] pci 0002:00:00.0: PCI bridge to [bus 00]
[    0.294748] pci 0002:00:00.0:   bridge window [mem 0x1f80000000-0x1fbfffffff]
[    0.294765] pci 0002:00:00.0: PME# supported from D0 D3hot
[    0.295285] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.397506] brcm-pcie 1000120000.pcie: clkreq-mode set to default
[    0.397508] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[    0.397533] pci 0002:01:00.0: [1de4:0001] type 00 class 0x020000 PCIe Endpoint
[    0.397546] pci 0002:01:00.0: BAR 0 [mem 0xffffc000-0xffffffff]
[    0.397552] pci 0002:01:00.0: BAR 1 [mem 0xffc00000-0xffffffff]
[    0.397558] pci 0002:01:00.0: BAR 2 [mem 0xffff0000-0xffffffff]
[    0.397621] pci 0002:01:00.0: supports D1
[    0.397623] pci 0002:01:00.0: PME# supported from D0 D1 D3hot D3cold
[    0.405512] pci_bus 0002:01: busn_res: [bus 01-ff] end is updated to 01
[    0.405520] pci 0002:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]: assigned
[    0.405523] pci 0002:01:00.0: BAR 1 [mem 0x1f00000000-0x1f003fffff]: assigned
[    0.405527] pci 0002:01:00.0: BAR 2 [mem 0x1f00400000-0x1f0040ffff]: assigned
[    0.405530] pci 0002:01:00.0: BAR 0 [mem 0x1f00410000-0x1f00413fff]: assigned
[    0.405534] pci 0002:00:00.0: PCI bridge to [bus 01]
[    0.405537] pci 0002:00:00.0:   bridge window [mem 0x1f00000000-0x1f005fffff]
[    0.405539] pci_bus 0002:00: resource 4 [mem 0x1f00000000-0x1ffffffffb]
[    0.405541] pci_bus 0002:00: resource 5 [mem 0x1c00000000-0x1effffffff pref]
[    0.405543] pci_bus 0002:01: resource 1 [mem 0x1f00000000-0x1f005fffff]
[    0.405546] pci 0002:00:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    0.405553] pci 0002:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    0.405606] pcieport 0002:00:00.0: enabling device (0000 -> 0002)
[    0.405632] pcieport 0002:00:00.0: PME: Signaling with IRQ 38
[    0.405681] pcieport 0002:00:00.0: AER: enabled with IRQ 38
[    0.405741] rp1 0002:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[    0.405744] rp1 0002:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[    0.405755] rp1 0002:01:00.0: enabling device (0000 -> 0002)
[    0.406354] rp1 0002:01:00.0: chip_id 0x20001927
[    0.411273] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.411674] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[    0.412122] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.412506] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[    0.412914] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[    0.413308] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[    0.413435] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[    0.413521] mmc0: CQHCI version 5.10
[    0.413830] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 100
[    0.414021] mmc1: CQHCI version 5.10
[    0.427336] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 106 (2c:cf:67:55:1a:27)
[    0.427996] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[    0.428180] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    0.428185] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[    0.428618] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000808000000810
[    0.428632] xhci-hcd xhci-hcd.0: irq 131, io mem 0x1f00200000
[    0.428686] xhci-hcd xhci-hcd.0: xHCI Host Controller
[    0.428689] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[    0.428691] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[    0.428729] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    0.428732] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.428734] usb usb1: Product: xHCI Host Controller
[    0.428736] usb usb1: Manufacturer: Linux 6.12.47+rpt-rpi-2712 xhci-hcd
[    0.428737] usb usb1: SerialNumber: xhci-hcd.0
[    0.428829] hub 1-0:1.0: USB hub found
[    0.428841] hub 1-0:1.0: 2 ports detected
[    0.428937] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[    0.428940] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.428942] usb usb2: Product: xHCI Host Controller
[    0.428943] usb usb2: Manufacturer: Linux 6.12.47+rpt-rpi-2712 xhci-hcd
[    0.428945] usb usb2: SerialNumber: xhci-hcd.0
[    0.429002] hub 2-0:1.0: USB hub found
[    0.429011] hub 2-0:1.0: 1 port detected
[    0.429217] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    0.429221] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[    0.429651] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000808000000810
[    0.429659] xhci-hcd xhci-hcd.1: irq 136, io mem 0x1f00300000
[    0.429710] xhci-hcd xhci-hcd.1: xHCI Host Controller
[    0.429712] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[    0.429714] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[    0.429740] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    0.429743] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.429745] usb usb3: Product: xHCI Host Controller
[    0.429746] usb usb3: Manufacturer: Linux 6.12.47+rpt-rpi-2712 xhci-hcd
[    0.429748] usb usb3: SerialNumber: xhci-hcd.1
[    0.429816] hub 3-0:1.0: USB hub found
[    0.429829] hub 3-0:1.0: 2 ports detected
[    0.429913] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.12
[    0.429915] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.429917] usb usb4: Product: xHCI Host Controller
[    0.429918] usb usb4: Manufacturer: Linux 6.12.47+rpt-rpi-2712 xhci-hcd
[    0.429920] usb usb4: SerialNumber: xhci-hcd.1
[    0.429977] hub 4-0:1.0: USB hub found
[    0.429986] hub 4-0:1.0: 1 port detected
[    0.430688] of_cfs_init
[    0.430711] of_cfs_init: OK
[    0.430774] clk: Disabling unused clocks
[    0.439515] PM: genpd: Disabling unused power domains
[    0.445510] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[    0.545996] mmc0: new ultra high speed SDR104 SDHC card at address aaaa
[    0.546147] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    0.548119]  mmcblk0: p1 p2
[    0.548179] mmcblk0: mmc0:aaaa SC16G 14.8 GiB (quirks 0x0000c000)
[    0.600036] mmc1: SDHCI controller on 1001100000.mmc [1001100000.mmc] using ADMA 64-bit
[    0.609538] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    0.609541] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    0.630109] mmc1: new ultra high speed DDR50 SDIO card at address 0001
[    0.673505] usb 1-1: new low-speed USB device number 2 using xhci-hcd
[    0.677502] usb 3-2: new low-speed USB device number 2 using xhci-hcd
[    0.848834] usb 3-2: New USB device found, idVendor=045e, idProduct=0084, bcdDevice= 0.00
[    0.848838] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    0.848840] usb 3-2: Product: Basic Optical Mouse
[    0.848842] usb 3-2: Manufacturer: Microsoft
[    0.877788] input: Microsoft Basic Optical Mouse as /devices/platform/axi/1000120000.pcie/1f00300000.usb/xhci-hcd.1/usb3/3-2/3-2:1.0/0003:045E:0084.0001/input/input0
[    0.877848] hid-generic 0003:045E:0084.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Basic Optical Mouse] on usb-xhci-hcd.1-2/input0
[    0.904813] usb 1-1: New USB device found, idVendor=04d9, idProduct=0024, bcdDevice= 3.90
[    0.904816] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    0.904818] usb 1-1: Product: USB Keyboard
[    0.904819] usb 1-1: Manufacturer: Chicony
[    0.972780] input: Chicony  USB Keyboard as /devices/platform/axi/1000120000.pcie/1f00200000.usb/xhci-hcd.0/usb1/1-1/1-1:1.0/0003:04D9:0024.0002/input/input1
[    0.991370] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    0.992764] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted
[    0.992767] EXT4-fs (mmcblk0p2): recovery complete
[    1.011074] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
[    1.011090] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.011541] devtmpfs: mounted
[    1.014271] Freeing unused kernel memory: 5696K
[    1.014363] Run /sbin/init as init process
[    1.014365]   with arguments:
[    1.014366]     /sbin/init
[    1.014367]     splash
[    1.014368]   with environment:
[    1.014369]     HOME=/
[    1.014370]     TERM=linux
[    1.081563] hid-generic 0003:04D9:0024.0002: input,hidraw1: USB HID v1.10 Keyboard [Chicony  USB Keyboard] on usb-xhci-hcd.0-1/input0
[    1.172727] input: Chicony  USB Keyboard Consumer Control as /devices/platform/axi/1000120000.pcie/1f00200000.usb/xhci-hcd.0/usb1/1-1/1-1:1.1/0003:04D9:0024.0003/input/input2
[    1.229560] input: Chicony  USB Keyboard System Control as /devices/platform/axi/1000120000.pcie/1f00200000.usb/xhci-hcd.0/usb1/1-1/1-1:1.1/0003:04D9:0024.0003/input/input3
[    1.229602] hid-generic 0003:04D9:0024.0003: input,hidraw2: USB HID v1.10 Device [Chicony  USB Keyboard] on usb-xhci-hcd.0-1/input1
[    1.274109] systemd[1]: System time before build time, advancing clock.
[    1.346341] NET: Registered PF_INET6 protocol family
[    1.346641] Segment Routing with IPv6
[    1.346648] In-situ OAM (IOAM) with IPv6
[    1.371822] systemd[1]: systemd 252.39-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[    1.371829] systemd[1]: Detected architecture arm64.
[    1.377251] systemd[1]: Hostname set to <guitarpi>.
dmesg.log continued
[    1.656158] systemd[1]: /lib/systemd/system/memlockd.service:8: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
[    1.744473] systemd[1]: Queued start job for default target graphical.target.
[    1.785928] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    1.786147] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    1.786310] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    1.786472] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[    1.786564] systemd[1]: Created slice user.slice - User and Session Slice.
[    1.786615] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    1.786752] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    1.786772] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-17771377\x2d01.device - /dev/disk/by-partuuid/17771377-01...
[    1.786780] systemd[1]: Expecting device dev-dri-card0.device - /dev/dri/card0...
[    1.786786] systemd[1]: Expecting device dev-dri-renderD128.device - /dev/dri/renderD128...
[    1.786793] systemd[1]: Expecting device dev-ttyAMA10.device - /dev/ttyAMA10...
[    1.786815] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[    1.786844] systemd[1]: Reached target nss-user-lookup.target - User and Group Name Lookups.
[    1.786866] systemd[1]: Reached target slices.target - Slice Units.
[    1.786884] systemd[1]: Reached target swap.target - Swaps.
[    1.786908] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[    1.787008] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[    1.787051] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    1.787238] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    1.787321] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    1.787403] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[    1.790030] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    1.790094] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    1.790197] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    1.790716] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    1.791372] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    1.792016] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    1.792146] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    1.794061] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[    1.795051] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    1.796008] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    1.796959] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    1.798079] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[    1.799237] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    1.800368] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    1.801495] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    1.802666] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
[    1.804139] systemd[1]: Starting systemd-fsck-root.service - File System Check on Root Device...
[    1.805706] systemd[1]: Starting systemd-journald.service - Journal Service...
[    1.816673] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    1.817603] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    1.818735] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    1.818814] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    1.818861] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    1.821533] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    1.821866] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    1.821963] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    1.822141] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    1.822214] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    1.822401] systemd[1]: modprobe@loop.service: Deactivated successfully.
[    1.822491] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
[    1.822892] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@lists.linux.dev
[    1.823385] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    1.824330] systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status.
[    1.824864] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[    1.825064] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[    1.825879] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[    1.826029] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[    1.833574] fuse: init (API version 7.41)
[    1.834238] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    1.834344] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    1.835105] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    1.836696] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[    1.857695] systemd[1]: Started systemd-journald.service - Journal Service.
[    1.886861] i2c_dev: i2c /dev entries driver
[    2.020493] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w.
[    2.072496] systemd-journald[158]: Received client request to flush runtime journal.
[    2.086859] systemd-journald[158]: File /var/log/journal/c06a9a458509498e8d88e5c57a8f177a/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    2.388984] systemd-journald[158]: Failed to read journal file /var/log/journal/c06a9a458509498e8d88e5c57a8f177a/user-1000.journal for rotation, trying to move it out of the way: Device or resource busy
[    2.918298] rp1-firmware rp1_firmware: RP1 Firmware version eb39cfd516f8c90628aa9d91f52370aade5d0a55
[    2.918362] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[    2.918760] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[    2.918901] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[    2.918975] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[    2.919000] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[    2.919035] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[    2.919053] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[    2.919788] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[    2.919858] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[    2.919911] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[    2.961974] input: pwr_button as /devices/platform/pwr_button/input/input4
[    2.962229] brcmstb-i2c 107d508200.i2c:  @97500hz registered in interrupt mode
[    2.962900] brcmstb-i2c 107d508280.i2c:  @97500hz registered in interrupt mode
[    2.963444] rp1-pio 1f00178000.pio: Created instance as pio0
[    3.004701] v3d 1002000000.v3d: [drm] Transparent Hugepage support is recommended for optimal performance on this platform!
[    3.006752] mc: Linux media interface: v0.10
[    3.022136] [drm] Initialized v3d 1.0.0 for 1002000000.v3d on minor 0
[    3.038112] videodev: Linux video capture interface: v2.00
[    3.091909] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    3.091929] pispbe 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    3.091946] pispbe 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    3.091960] pispbe 1000880000.pisp_be: Adding to iommu group 0
[    3.091973] pispbe 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    3.095150] pisound: Using SPI speed: 100000
[    3.095165] pisound: Searching for spi device...
[    3.095172] pisound: 	Found!
[    3.101947] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[    3.101955] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[    3.101962] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[    3.101967] rpi-hevc-dec 1000800000.codec: Adding to iommu group 0
[    3.101969] rpi-hevc-dec 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[    3.110299] rpi-hevc-dec 1000800000.codec: Device registered as /dev/video19
[    3.117881] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.126208] Loaded X.509 cert 'benh@debian.org: 577e021cb980e0e820821ba7b54b4961b8b4fadf'
[    3.126415] Loaded X.509 cert 'romain.perier@gmail.com: 3abbc6ec146e09d1b6016ab9d6cf71dd233f0328'
[    3.126608] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.126798] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    3.178506] Bluetooth: Core ver 2.22
[    3.178536] NET: Registered PF_BLUETOOTH protocol family
[    3.178538] Bluetooth: HCI device and connection manager initialized
[    3.178544] Bluetooth: HCI socket layer initialized
[    3.178546] Bluetooth: L2CAP socket layer initialized
[    3.178550] Bluetooth: SCO socket layer initialized
[    3.186714] vc4_hvs 107c580000.hvs: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    3.186721] vc4_hvs 107c580000.hvs: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    3.186726] vc4_hvs 107c580000.hvs: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    3.186731] vc4_hvs 107c580000.hvs: Adding to iommu group 1
[    3.186735] vc4_hvs 107c580000.hvs: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    3.187260] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[    3.187264] vc4-drm axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[    3.187268] vc4-drm axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[    3.187271] vc4-drm axi:gpu: Adding to iommu group 1
[    3.187273] vc4-drm axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[    3.193058] Console: switching to colour dummy device 80x25
[    3.194183] brcmfmac: F1 signature read @0x18000000=0x15264345
[    3.196057] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    3.196877] usbcore: registered new interface driver brcmfmac
[    3.197434] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[    3.200133] Bluetooth: HCI UART driver ver 2.3
[    3.200140] Bluetooth: HCI UART protocol H4 registered
[    3.200164] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.200282] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator
[    3.200325] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator
[    3.200932] Bluetooth: HCI UART protocol Broadcom registered
[    3.229006] pisound: Detected Pisound card:
[    3.229013] pisound: 	Serial:           PS-1M24N30
[    3.229015] pisound: 	Firmware Version: 1.03
[    3.229016] pisound: 	Hardware Version: 1.2
[    3.229017] pisound: 	Id:               1e9315324431363532050930
[    3.230209] Registered IR keymap rc-cec
[    3.237237] rc rc0: vc4-hdmi-0 as /devices/platform/soc@107c000000/107c701400.hdmi/rc/rc0
[    3.237456] input: vc4-hdmi-0 as /devices/platform/soc@107c000000/107c701400.hdmi/rc/rc0/input5
[    3.305066] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc@107c000000/107c701400.hdmi/sound/card1/input6
[    3.308780] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[    3.310238] Registered IR keymap rc-cec
[    3.310284] rc rc1: vc4-hdmi-1 as /devices/platform/soc@107c000000/107c706400.hdmi/rc/rc1
[    3.310330] input: vc4-hdmi-1 as /devices/platform/soc@107c000000/107c706400.hdmi/rc/rc1/input7
[    3.310820] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc@107c000000/107c706400.hdmi/sound/card2/input8
[    3.311767] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[    3.311873] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[    3.311922] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[    3.311968] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.312011] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[    3.372898] [drm] Initialized vc4 0.0.0 for axi:gpu on minor 1
[    3.444854] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[    3.445115] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Aug 29 2023 01:47:08 version 7.45.265 (28bca26 CY) FWID 01-b677b91b
[    3.450809] Console: switching to colour frame buffer device 160x64
[    3.468073] vc4-drm axi:gpu: [drm] fb0: vc4drmfb frame buffer device
[    3.553942] Bluetooth: hci0: BCM: chip id 107
[    3.554178] Bluetooth: hci0: BCM: features 0x2f
[    3.555328] Bluetooth: hci0: BCM4345C0
[    3.555332] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[    3.559454] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.raspberrypi,5-model-b.hcd' Patch
[    3.730499] export_store: invalid GPIO 17
[    3.990308] Adding 524272k swap on /var/swap.  Priority:-2 extents:8 across:2228224k SS
[    4.234537] Bluetooth: hci0: BCM: features 0x2f
[    4.235911] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+-0190
[    4.235916] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0382
[    4.236251] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[    5.117764] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[    5.117773] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[    5.121681] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[    5.130371] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
Ok, this seems to be problematic - the resistance should be close to zero, < 0.3 Ohm. Just to confirm, you measured it while Pisound is unpowered? Also double check whether the contacts measured are exactly as marked on the picture.
If it’s indeed very high resistance, these marked areas might be the cause of this. The trace damage can be repaired by carefully scraping off the green solder mask at the impacted area, and building a thin layer of solder bridge, using a bare wire if necessary, in case the distance is too big to make it with solder alone, restoring the connection.
See this video for the process:
I measured again at the same place. Here:
But surprisingly, this time I found the expected resistance of 0.3Ohms…
Here are some detailed photos of the scratches you noticed:
Is it still interesting to rebuild the traces, even if the resistance is OK? The surface is clearly scratched as I measured a continuity between the two scratches, showing that the copper is exposed, at least. I’m conscient that the trace itself can be broken, or not.
The video is very clear. Thanks.
Yeah, sometimes some thin layer of flux or oxidation inhibits proper measurements, in that case, slight scratching up of the surface or more force helps measure accurately.
In that case, the scratches don’t seem to be the problem.
I don’t visually see any other issues. Please try cleaning up the soldered pins, just in case they are making contact with something they shouldn’t be contacting with.
Hi, I cleaned the pins:
It’s not perfect. I should improve the connections, but at leas I think we can exclude unvisible shorts.
Unfortunately, this is still the same: drivers see the pisound. It is selected as source and sink in wireplumber with volumes at 1.0. But there is still input/output errors on arecord and on speaker-test.
The pins now look much better, good improvement!
After you run speaker-test, do any new messages appear in the dmesg log?
Here are the messages that appear on running speaker-test:
dm2chan4 failed to stop
dm2chan4 is non-idle!
These appear in the dmesg log? Could you post the entire contents?
Yes, I ran dmesg -w and these line appeard during the execution of speaker-test.
Here is the full log:
dmesg.log (43.4 KB)
Hi, just a little ping in case this has slept out of your view :blush:.
I start to wonder if I should buy a second pisound :slightly_frowning_face:
Or is there possibilities to send my current one back for repair?
Indeed, it slipped my view. :slight_smile: I suspect this line might appear due to PCM FS or PCM CLK pin connectivity issues, but as hard as I looked into your photos, I couldn’t find any troubling spots.
We could look into repairing your Pisound, please send us an email with your details.
I’m very late for this followup, but let’s close this case beautifully.
I sent my Pisound to Blokas and very quickly after, I got the verdict: I burnt two important components (the ADC and another one) due to a short, probably caused by a scratch I made. Shame on me…
Well, they repaired my device and sent it back for a fraction of the cost of a brand new Pisound. It was good for me and for the planet, avoiding to just throw away a nearly good device.
This is the sign of a very serious and ethical business.
Thank you.
