Here is a simple patch which has two purposes:
– Make it easier to map and select properties of CHANCE modifier pipe with MIDI controller knobs
– Demonstrate an easy application of MIDI TRHU loopback idea which can be used for other purposes as well. This idea allows to control Midihub with itself.
[Better CHANCE with THRU loopback | Patchstorage]
This is a simpler demonstration of THRU loopback discussed earlier in this thread: Are mapped values processed by pipes?
I hope this patch makes the THRU loopback idea easier to use in your patches
Cheers!
U
