[Beta Program] [Hardware] Print is peeling off
Unfortunately, after a using MIDIhub now for a while, I discovered, that the white print is peeling off. The IN Label is also gone already.
The Color is too sensitive and even light rubs peel it off…
Hey! Thank you for reporting this, the m went off on my unit as well. :slight_smile: The paint finish is going to have sand texture in the public version of Midihub, it should retain the silkscreen better.
