[Beta Program] [Editor] Midihub editor bugs
Let’s collect bugs in one topic:
MAC Version:
  1. Items in pipe panel: once clicked on one object in the pipe panel, the objects are highlighted (grey frame) and then stay highlighted.
Same on the Windows version. Thanks for pointing this out. :wink:
not sure if it’s a bug or feature and if it belongs here
the midihub gives me 5 Midiports - but actually there are only 4 usb-ports in the editor
edit: ok I read that the 5th port shouldn’t be used… I think thats confusing and either it should be named differently or hidden
Unfortunately Midihub is not in control of the naming - the various different OSes take care of that via their MIDI driver impementations.
Do you have a suggestion for the best place to put this information, so it’s noticeable and clear to the user, and can’t be missed?
good question … currently it’s in a longer text wich you have to read fully and scroll down to figure this out
(wich is why I was missing that information first)
maybe a quick-tutorial wich covers the most important points and concepts of Midihub -ideally on a real-life usage example
or in a manual could be a feature-list wich says
4 USB I/O ports (please don’t use the fifth as it’s only for internal communication)
We’ll very likely have a short ‘Getting Started’ guide printed for the retail version, and some more material on the website for the device where we could mention this point.
This kind of feedback is really helpful for us to know which things to state more explicitly. :slight_smile:
Hey there,
This might be me being noob-ish, but I can’t get the note remap to work as I intend (I think there is a similar problem with channel remap…)
I try to remap only 1 note (say 70) to another (say 100) .
So my “Out Settings” are : Out Low 100 / Out High 100.
This does work as it remaps every note to 100.
Now my IN settings … If I set it as “In Low 69 / In High 71” it remaps every note between 69 and 71 (included) to 100. Works with 70/71 as well…
But as soon as the In Low and In High are the same value ( 70 ) the output note is dropped as low as possible (lowest C). It looks like a bug, and it has this behavior regardless of the input value (as long as both in are set the same).
I think it does the same thing with channel remap, outputting only on channel 10 when both the In low and In high are set to the same value.
In summary, I can’t remap a single note. The remap pipe needs to have at least 2 notes input (which isn’t practical as I’m trying to remap each adjacent notes individually)
I don’t know if that makes sens, in any case, hit me up if you need me to reformulate or to try to explain things differently …
Let me know,
Cheers
Maxime
Thank you for noticing this, indeed this is a bug, it should work as you expect. We’ll fix it in the next update.
this happens quite often to me:
if I add a note-remap into an active midi-stream (say a note-sequence of a midi-sequencer) and change there value of the note-remapper it results in a permanent very low note. I have to force my sequencer to send a note- off for all notes to quit this note
unfortunately I cannot replicate this always - maybe this is related to the just before mentioned issue
and something else:
i have the following setup:
I’m just experimenting to create chord-generator - the synth that receives it is on midi-outA
the top-row should do some basic shifting of the sequence and send it to a virtual port
the second, third and fourth row take the input from he virtual input build the chord by using different transposes and send it to midiout-A
the last row just sends the data to my midi-monitor
why is the just selected transpose in the third row actually changing the midi data - I would expect that it actually doesn’t send anything as no output is defined
btw it would be nice to have an easy way to disable the output of a certain row (instead of deleting the output module)
Thank you for the reports. Yes, there shouldn’t be a low note remaining, and it could be related to that previous issue. I’ll try and see if I can reproduce this. Btw, you can send ‘all notes off’ by holding down the button for a second or so, see device->settings menu to customize the behavior.
Could you attach a .mhp file to this post that shows the issue above?
I found out how to replicate the infinity held note :
open my example mhp-file Midihub 2018.09.27 16.10.24.mhp (57 Bytes)
play a midi sequence with at least one longer note
change the “out low” value of the note-remapper- hit ok while the long note of the midi-sequence plays
then this note will play forever
delete the note-remapper in the right moment and you’ll get a very low infinity note
the same happens with just a transpose operator
But since you’re remapping on the fly wouldn’t a held note be expected? Unless Midihub ends NoteOff for every remapping that is changed during operation.
We could experiment with sending an ‘all notes off’ CC command whenever a parameter that could cause a stuck note is tweaked to the affected output ports. I think we’ll do that and see how well it works in practice.
