Hi All!
I’m currently developing a simple Bank Select (MIDI CC 0 & 32) and Program Change remap patch for a blind friend. He want’s to use Korg RK-100 to select patches on his Roland Integra 7, however the keytar doesn’t have editable PC messages so it only spits out PC from 0 to 199.
The patch I came up with has 4 transformations per individual PC which is not very elegant. I’ve seen others tried different methods (e.g. to transform via Note On events), but there doesn’t seem to be a simple way to do this.
Now the feature request I would like to propose is to have a editable “map” of the Bank Select & Program Changes.
For example the user could setup the following pair:
“CC#0 = 1 / CC#32 = 1 / PC = 1” → “CC#0 = 5 / CC#32 = 6 / PC = 7”
When Midihub receives the respective CC/PC combination it will transform it to the new CC/PC combination.
In some sense this replaces if-logic and transformations that would be otherwise needed.
This can be hard-coded to CC#0, CC#32 and PC, since most of the hardware uses these messages to select programs/patches.
Hope this makes sense! Let me know in case of questions ![]()
