Pisound was working for a few days, then I switched the bitrate to 192 and output stopped. I switched back to 48 in pure data and still not working. The output is not working with VLC or anything else now.
I uninstalled and reinstalled the OS and all the pisound install files, still not working.
Audio in is working and so is MIDI - tested using Pure Data.
Is there a way to reset the soundcard?
What else should I try?
